Forums >> Revit Structure >> Technical Support >> 6"x48" Herringbone .pat revit file help
Mon, Jul 20, 2015 at 2:28:49 PM | 6"x48" Herringbone .pat revit file help
akneller
I am trying to write a .pat file for a 6"x48" herringbone pattern but I am having a lot of trouble and was wondering if anyone could help.
This is what I have so far:
*HerringBone 2x6,  brick herringbone
;%TYPE=MODEL
45,            0,             0,             6,             6,             48,             -24
135,
Not sure if this is right, but I have no clue how to get the 2nd and 3rd number in the second row. If someone could help, I would appreciate it.
Thanks!
Mon, Jul 20, 2015 at 5:00:36 PM | 6"x48" Herringbone .pat revit file help
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Here you go:
45,        0,            0,            6,       6,      54,      -42
135,      4.243,      -4.243,      6,      -6,      54,      -42
Tue, Jul 21, 2015 at 7:05:21 AM | 6"x48" Herringbone .pat revit file help
akneller
Thanks so much! How did you know what numbers to write?
Tue, Jul 21, 2015 at 10:09:08 AM | 6"x48" Herringbone .pat revit file help
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Take a look in the revit.pat file (C:\Program Files\Autodesk\<your revit version>\Data), at the beginning, there is an explanation/meaning of these numbers. Also, take a look at Tim’s pdf file here.
4" X 24 " orthogonal Herringbone Pattern .pat
Sun, Oct 20, 2019 at 7:46:07 AM
6x12 Herringbone Pattern .pat file help
Tue, May 1, 2018 at 8:05:16 PM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
help with .pat custom file.
Mon, Oct 13, 2008 at 8:25:57 AM
How do i make an allternating horizontal 4" and 8" .pat file in notepad???
Tue, Sep 6, 2011 at 6:32:54 PM
Page generation time: 3.6851
