67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Placing Rebar Problem
Sat, Jul 11, 2015 at 8:45:11 AM | Placing Rebar Problem
noman93
I am Muhammad Noman. I am civil engineer now. I have just started this remarkable software called REVIT. I learned many things from the tutorials which are uploaded on youtube.
Now back to the problem for which i need your suggestions.
I have to place rebars on revit. but the problem is during placing. reinforcement place from bottom to top. and i have two storey structure. 1st floor has different cross section column having different amount of steel while the second floor has different cross section column and different amount of steel. how can i place the bars level by level??
suggest me and kindly teach me step by step.
Thanks for your all co-operation in advance.
Placing Rebar/Strand in Walls
Fri, Apr 10, 2015 at 4:04:48 PM
Placing Rebar in a CMU wall
Fri, Dec 5, 2008 at 5:18:38 AM
Placing Rebar in Curved and Swept Walls
Thu, Jun 22, 2017 at 2:58:23 PM
Problem Linking DWG Files Showing Rebar as Polyline
Tue, Jan 22, 2008 at 11:07:56 AM
How to apply the rebar in a ramp.
Mon, Jul 5, 2010 at 4:53:04 AM
Page generation time: 0.5564
