59 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> stairs lines "override" walls
Good afternoon everyone!
Please help!
I have a problem with stair (actually, walls) visibility:
my STAIRS, where are ABOVE the cutting line and are not visible (because the lines there are white), BLOCK the wall contours with their white dashed lines. Please see the image. (Revit 2013).
VV are virgin, NO overrides, no linework.
The SAME stairs in other projects with the SAME Object Styles are OK.
To change “<Above> Supports” to black is not a solution.
Thank you.
Why did you make these lines white? Simply turn the lines off in VG.
Thanks!
You saved me. I know, it was obvious, but somtimes one just can't see what is on the surface.
Thanks again.
Dimension Override / The Ghost 1/32" |
Tue, Jul 8, 2008 at 9:30:09 PM
Stairs in RCPs |
Tue, May 26, 2009 at 9:14:41 AM
Wall Sweeps in Visibilty Graphics |
Wed, Jan 20, 2010 at 12:10:08 PM
Dimension Override |
Wed, Apr 12, 2006 at 3:17:15 PM
Imported Cad Lines not "live" [ 1 2 ] |
Fri, Aug 15, 2008 at 2:02:40 PM
15
