72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Grid line width issue
Wed, Jun 3, 2015 at 5:28:37 AM | Grid line width issue
Nalivay
Hello, I've set grid line thicknes to 1, but it is still thicker then other objects with the same 1 lineweight. If i change it for 2 it becomes thicker, so in general I am able to change thickness but at 1 value it is differrent. What could be wrong? Thank you!
Wed, Jun 3, 2015 at 10:53:29 AM | Grid line width issue
Grids are annotative.  They are a fixed size in relation to paper space.   All model elements change model pen size based on object style then view scale settings in your lineweights chart.   Pen one is set initially to be the same at every scale.
Wed, Jun 3, 2015 at 11:11:34 AM | Grid line width issue
Nalivay
Thank you! It works for me.
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Multi Segment Grid Line Bubble Issue
Wed, Dec 11, 2013 at 2:52:11 PM
Curved/Arc Grid Line - NOT DASHED
Thu, Oct 13, 2011 at 11:22:19 PM
Width on Either side of Curtain Wall Mullions Greyed Out
Sun, Jun 6, 2021 at 8:10:39 PM
Space between Grid Head and Grid Line not wanted!
Mon, Jan 28, 2013 at 4:14:54 PM
Page generation time: 0.6666
