Forums >> General Discussion >> Revit Project Management >> Revit Suite Workflows problem
Sun, May 17, 2015 at 4:40:16 PM | Revit Suite Workflows problem
vazelos87
Hello, I am trying to export a model from Revit to 3ds Max using the Suite Workflows option in Revit. The problem is no matter what combination method I choose (combine by material is the one I want), the final project in 3ds Max is not combined the way I chose. I could import it from 3ds using Link Revit but that way causes some visual issues on cylindrical models (eg columns). The cylinder is smoothed all the way around (with auto-smooth checked in the link options) but always one or 2 edges are visible and not smoothed out. This issue does not occur if I use the built in Revit workflow but then the problem is it does not combine by material. Generally what I see is a very poor job as a matter of autodesk's programms synergy.. Anyone has any idea how that can be fixed? Thanks.
BIM Manager Suite
Wed, Jul 2, 2014 at 7:38:50 AM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:55 AM
Tag Suite and Maintain Rooms
Mon, Oct 28, 2013 at 8:58:38 AM
suite or plain Revit Arch?
Thu, Nov 1, 2007 at 8:54:15 AM
WORKSET CAN'T CREATE IN DIFFERENCE SUITE SET
Tue, Jun 11, 2013 at 8:40:56 AM
Page generation time: 1.9572
