38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Wall surface patterns not showing under variable finish surface
11 Posts No Rating |
I am not sure I am going about this the right way but I am trying to construct a wall which has a brick plinth and render which starts at 975 above the foundation height. I have created this as attached. The render layer is unlocked so I can move this up to the line that the concrete masonry blocks start. However in elevation the surface pattern for the 'common brick' does not show.
Is there a reason for this? Is there a way to lock the render layer to the 975 heights as well? I tried spliting the render layer and changing the lower section to air but this did not seem to help.
Any advice apprecaited.
Many Thanks,
Simon
Stacked Walls! Knew I would find the answer as soon as I posted
scale surface patterns |
Fri, Aug 15, 2008 at 1:38:43 PM
materail surface patterns |
Fri, Jun 13, 2008 at 8:06:11 AM
Surface Patterns in Perspective |
Fri, Jan 27, 2012 at 7:04:34 AM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
Sloped Ceiling Surface Pattern Not Visibile |
Sun, Jun 26, 2016 at 7:21:36 PM
