Forums >> Revit Building >> Technical Support >> Radius Type Paramter
Fri, Mar 20, 2015 at 5:06:49 PM | Radius Type Paramter
jotagarza12
Newer Revit user.  I am trying to include the radius of a set of steel members in a schedule so we can order HR steel from a fabricator.  There are a couple hundered members, most with varying radii.  In the past I have manually created a spreadsheet from information aquired from rhino 3D models, but as we make a transition to Revit I would like this to be an automated process obviously.  Thank you for your help in advance.
Jaime Garza
Fri, Mar 20, 2015 at 5:14:55 PM | Radius Type Paramter
jotagarza12
Forgot; Revit Architecture 2015
Circular Windows
Fri, Dec 21, 2007 at 4:40:04 PM
Structural Discipline Type of Parameter
Wed, Feb 25, 2009 at 9:21:05 AM
Parametric Circular Column...Offset issues
Tue, Jul 17, 2012 at 12:42:38 PM
Radius window jambs
Fri, Jul 6, 2007 at 8:55:13 PM
column height paramter
Wed, Sep 26, 2007 at 9:11:53 AM
Page generation time: 0.8879
