Forums >> Revit Building >> Technical Support >> Shadow density / weight
Fri, Feb 6, 2015 at 11:53:09 AM | Shadow density / weight
elizabethpetermathew
I woudl like to lighten the shadow greyness and make it also more transparent on my exterior elevations. How do I adjust the setting? Thank you in advance.
Fri, Feb 6, 2015 at 12:13:47 PM | Shadow density / weight
Here - graphic display options ... above transparent/hidden...etc.
Fri, Feb 6, 2015 at 12:19:57 PM | Shadow density / weight
Thank you, it worked. Also is there a way of highlighting the silhouttes of walls in front to be darker than walls behind?
Fri, Feb 6, 2015 at 12:33:32 PM | Shadow density / weight
Linework tool or over-ride graphics in view by element.
I typically pick the furthur back elements and over-ride graphics in view making them all halftone.
Fri, Feb 6, 2015 at 12:47:56 PM | Shadow density / weight
Thank you, will try that.
Shadow Weight
Tue, Mar 13, 2007 at 8:10:36 AM
Point Cloud Density
Sun, Aug 14, 2011 at 9:23:44 AM
Shadow Casting
Thu, Feb 12, 2009 at 10:00:48 PM
Doors make a gray shadow in Sections
Wed, Apr 7, 2004 at 10:39:43 AM
Need to show shadow of canopy on ground
Mon, Dec 26, 2016 at 12:30:35 AM
Page generation time: 2.1508
