54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> reference plan not showing
Thu, Feb 5, 2015 at 2:19:09 PM | reference plan not showing
Warchitect
4 Stars: 5 Votes
So a reference plane (for my 6'8" height) only shows on my front elevation but not the side. Can seem to get it to show. dont want to delete it and its not hidden. any suggestions?
Thu, Feb 5, 2015 at 2:30:15 PM | reference plan not showing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your reference plane will only show in the view that it is perpendicular to.
Thu, Feb 5, 2015 at 2:33:13 PM | reference plan not showing
Reference planes are just like level planes..... They have a start and end.   If they don't extend into the view range, they will not show.
Thu, Feb 5, 2015 at 2:37:24 PM | reference plan not showing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
WWhub reference plance need to be perpendicular to the view to be seen in elevation.
Thu, Feb 5, 2015 at 2:38:06 PM | reference plan not showing
Warchitect
4 Stars: 5 Votes
Hmm Im confused. I placed the plane at 80" above the floor while in the front facade view. why wouldnt it show in the left right and side views as it is perpendicular. also, how does the view range work in this instance. if you draw a plane sholdnt is show in the other elevations?
lastly, the other reference plane set at 8 feet shows just fine. you can see it on the image I posted.
Edited on: Thu, Feb 5, 2015 at 2:41:06 PM
Thu, Feb 5, 2015 at 2:39:58 PM | reference plan not showing
Right teafoe but the problem here is the extends of the plane.   If it shows in front then the side view will also be perpindicular to the plane.
Thu, Feb 5, 2015 at 2:41:56 PM | reference plan not showing
Warchitect
4 Stars: 5 Votes
like this.
Thu, Feb 5, 2015 at 2:44:15 PM | reference plan not showing
Look below:
Plane is outside of the crop window in right view.
Thu, Feb 5, 2015 at 2:45:51 PM | reference plan not showing
Move your elevation view in or your plane out.....
Thu, Feb 5, 2015 at 3:10:49 PM | reference plan not showing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Show us an image of your floor plan showing where your reference planes are.  If its not an extents problem then WWHub is correct otherwise it is a problem as I described.
Thu, Feb 5, 2015 at 3:21:35 PM | reference plan not showing
Actually, if he just grabs the work plane in the 3D view where he has it shown and drags the right side grip to the right, then it will show up in that view.
Thu, Feb 5, 2015 at 4:03:01 PM | reference plan not showing
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Another quick fix is to select a ref plane, right click and ‘maximize 3D extents’, done.
Thu, Feb 5, 2015 at 4:09:08 PM | reference plan not showing
#13
Warchitect
4 Stars: 5 Votes
Thanks all for the great help. the maximize in 3D was very simple fix.
Showing wrong reference sheet on view title
Wed, Oct 17, 2018 at 12:26:30 AM
14
Section title line showing wrong reference sheet
Thu, May 5, 2011 at 11:02:24 AM
Roof Plan not Showing in Site Plan
Wed, Jul 12, 2017 at 12:03:32 PM
11
Cars not showing in renderings but showing in site plan, help hurry please
Fri, May 6, 2011 at 6:01:49 PM
component above view range not showing up in plan
Thu, Oct 30, 2008 at 4:27:11 PM
Page generation time: 4.6585
