73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Metric Door Pemplate
Fri, Jan 30, 2015 at 4:07:37 AM | Metric Door Pemplate
tedkavanagh
I am new to RevitI I was playing around with the metric door template and have messed it up, when I go to the front elevation the word width is not at the top and when  select with on the dropdown I get a constraints warning which I cant get past.
Is there a way of resetting this template or other suggestions please?
Ted
Fri, Jan 30, 2015 at 8:37:53 AM | Metric Door Pemplate
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can try to restore the file to a previous date. Or reinstall revit. This should be a lesson learned to do a save as if youre not sure what your doing.
Project
Sun, Aug 13, 2006 at 1:06:05 PM
problems printing in metric
Wed, Aug 13, 2008 at 9:52:13 AM
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial to Metric
Fri, Aug 8, 2008 at 4:11:17 PM
Page generation time: 0.8767
