70 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> shared parameters listing
I have created a family called "Finish Key" with shared parameters. http://goo.gl/GW1OQ5 all the parameters have identical discipline and type. I insert the family into the project. Why do the parameters list like this... http://goo.gl/ha5VVA
Edited on: Sun, Jan 11, 2015 at 12:07:57 PM
Hi SteveB,
Not 100% sure if I know what the problem/solution is, but the second image you have displayed is the family's type parameters. Referring to your attached imaged, the actual "Type of Parameter" doesn't control where it ends up on the "Family Types"list but controls the input/content of the parameter value. Such as, Integer, Number, Text, etc.
I might be wrong, but I'm pretty sure you can NOT indicate within the shared parameter itself what the parameter's "Group" should be. Its a manual input process when the parameter is added to the family.
See attached. Hope this helped.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein |
Shared Parameters |
Thu, Feb 9, 2006 at 1:41:58 PM
Shared or Project Parameters? |
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families |
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters |
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid... |
Wed, Feb 12, 2014 at 9:31:26 AM
