Forums >> Revit Building >> Technical Support >> Start Revit 2015 as a Maximized window
Thu, Nov 27, 2014 at 5:48:15 PM | Start Revit 2015 as a Maximized window
iamian33
iamian33 Avatar
Greetings
I want to run a batch file that will start workshare Monitor, then Revit 2015 in a Maximized window but I cannot find the correct syntax ...
start /d "C:\Program Files\Autodesk\Revit 2015" Revit.exe /MAXstart /d "C:\Program Files\Autodesk\Worksharing Monitor for Revit 2015" WorksharingMonitor.exeexit
This Batch file works find except Revit opens in a Normal window, the /MAX switch does not work, actually it doesn't seem to do anything.
Does anyone have this knowledge??
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, Nov 27, 2014 at 5:49:26 PM | Start Revit 2015 as a Maximized window
iamian33
iamian33 Avatar
exit
...sorry, the lines got 'crushed' together ...
Ian Shafer
Maximizing Main Window on Startup
Thu, May 24, 2012 at 1:47:12 PM
WINDOW FAMILIES
Thu, May 24, 2007 at 5:46:09 PM
Opening a 2015 drawing in Revit 2014
Tue, Jul 29, 2014 at 9:11:58 AM
Revit 2015 Missing Family Template Files
Thu, Nov 13, 2014 at 6:45:25 PM
Window & door tag formatting
Tue, May 25, 2010 at 9:27:07 AM
Page generation time: 2.0920
