62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Armature radius too high - Model explodes - why? HELP. (see attached file)
Fri, Nov 7, 2014 at 2:42:56 PM | Armature radius too high - Model explodes - why? HELP. (see attached file)
kamf205
Hello,
So me and a colleague are working on designing a tensile membrane structure. There is a column and 4 beams coming out of the structure. We are modifying the dimensions to match the spec. However when we change the beam (armature) radius to its rightful value of 31330mm, the model sort of blows up? I dont know what's happening here, can somebody help?? Smile
Kay.
Kam
Fri, Nov 7, 2014 at 2:43:38 PM | Armature radius too high - Model explodes - why? HELP. (see attached file)
kamf205
You can try putting the value of 31330mm in as well, and see if it does the same thing
Kam
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:38 AM
Need a high-rise model shell file
Sun, Dec 9, 2007 at 4:58:36 PM
Need help creating a sloped slab with Radius Edge
Tue, May 2, 2006 at 5:23:52 PM
Radius window jambs
Fri, Jul 6, 2007 at 8:55:13 PM
Get the Radius of a Circle (model line)
Thu, Feb 9, 2012 at 9:12:58 AM
Page generation time: 1.4038
