46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> rotation of ceiling pattern
Fri, Oct 17, 2014 at 10:28:49 AM | rotation of ceiling pattern
SteveB
3.5 Stars: 5 Votes
I have  a site with several different axes of structures.  To accomodate, I rotate the view windows to get the plan to be orthagonal in the view.  within that rotated view, I created a sloping ceiling with a pattern.  It dipslays at an angle and I cant rotate the pattern or use the align command to change it.  http://screencast.com/t/CBXjDOgR      The ceiling pattern is 90degree   http://screencast.com/t/tFlvDJNjbWv    is there a setting that would control this?
Fri, Oct 17, 2014 at 10:56:10 AM | rotation of ceiling pattern
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you have a MODEL pattern on your ceiling you can click on the line of the pattern (make sure it is the pattern line) and rotate it to whatever angle you need
ceiling hatch pattern
Thu, Apr 17, 2014 at 6:59:10 AM
invisible ceiling pattern
Mon, Oct 17, 2011 at 7:20:11 AM
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
How to make ceiling grid with a pattern on it
Mon, Aug 11, 2008 at 2:21:07 PM
SURFACE PATTERN ROTATION
Fri, Feb 5, 2010 at 1:27:46 PM
Page generation time: 1.9995
