Forums >> Revit Building >> Technical Support >> Ceiling serious error
Wed, Oct 15, 2014 at 1:58:52 PM | Ceiling serious error
jazor
Hi there! I'm having a huge problem when trying to make a ceiling either with the automatic and the sketch tools. When I click on the tool button, a message appears informing there has been a serious error and asking if I want to save a recovery file, but however, the programme does not close, and if I select another tool, it works normally.
I re-installed and repaired the software, updated it, audited the file, unchercked hardware acceleration.... It only happens with this file, which is quite a big one (2000-2500 elements) but I'm desperate, because this file means my final project to become an architect. Hope someone can help me.
By the way, I'm using Revit 2014 (64bits).
Wed, Oct 15, 2014 at 3:21:42 PM | Ceiling serious error
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have all of the updates installed?
Thu, Oct 16, 2014 at 2:39:23 AM | Ceiling serious error
jazor
Yes, I installed them and nothing changed
Thu, Oct 16, 2014 at 10:41:17 AM | Ceiling serious error
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Do a saveas, create a new project and then load in a different but similar ceiling family and over write the old family.
Thu, Oct 16, 2014 at 10:59:43 AM | Ceiling serious error
jazor
After uninstalling, installing, updating, downloading hotfixes and many others, I've managed to solve it in a very simple way; I've transferred all the project standards to a new file and then copy-paste every single entity in the new file and it worked. There might be a bug or something in my old file.
Thank's anyway
Revit Ceiling Causing "Serious Error Has Occurred" Message
Thu, Aug 29, 2013 at 3:01:57 PM
Automatic Ceiling error - less than 150mm
Mon, Mar 3, 2014 at 7:40:48 AM
Sloping Ceiling
Mon, May 25, 2009 at 2:35:31 AM
Walls will not connect to ceiling or roof
Mon, Mar 2, 2015 at 8:25:47 AM
Ceiling Fixture Orientation
Tue, Sep 13, 2011 at 9:02:13 AM
Page generation time: 2.7041
