62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Room Sizes
Thu, Oct 9, 2014 at 8:01:48 AM | Room Sizes
graym
I am a teacher at a middle school and am teaching Revit to 7th graders.  They are working on a project were they are designing a house made of 4 shipping containers.  Each containers floor space is 20ft x 8ft.  The problem the students are running into is when they place their walls - both exterior and interior walls - the floor dimensions are not 20ft x 8ft or if they have a room 10ft x 8ft they end up with a smaller floor space.  This has to do with the wall, but I am not sure the setting they need to have so they end up with a floor space(area) of 20ft x 8ft or 10ft x 8ft if that is what they are going for.  We are very basic with Reivt so any help would be appreciated.  Thanks - Teacher of furture Architectures
Thu, Oct 9, 2014 at 8:22:37 AM | Room Sizes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You question is pretty unclear.  We don't know what your wall construction is so it is hard to say but when you dimension from your finish face for finish face of your INTERIOR walls just move your walls to make them the dimensions that you need them to be.
Thu, Oct 9, 2014 at 8:29:43 AM | Room Sizes
When you draw walls, you have an option for what reference to use:
  1. Wall centerline
  2. Core centerline
  3. Finish face exterior
  4. Finish face interior
  5. Core face exterior
  6. Core face interior.
If your 20x8 is finish interior, then use that reference and draw in a clockwise direction.
Room area calculations are set under the architecture/room and area pulldown / calculations / computations - set this to wall finish.
Thu, Oct 9, 2014 at 8:34:14 AM | Room Sizes
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Do you mean, the space is smaller by the wall thickness and you want the walls to be placed on the outside of 20’x8’ floor perimeter. After you activate the wall tool, on the option bar (right under the ribbon) for the location line pick finish face: interior.
Also, before you click the second point when placing the wall, you can hit the space bar to flip the wall.
Thu, Oct 9, 2014 at 9:33:51 AM | Room Sizes
graym
Here is a picture of what is happening to my students.
They would like the room on the left to have a floor dimension of 8x8 and the room on the right to have a floor dimension of 12x8.
Edited on: Thu, Oct 9, 2014 at 1:01:56 PM
Thu, Oct 9, 2014 at 9:44:35 AM | Room Sizes
Click on a wall and change the highlited dimension to what you need.
Room sizes
Wed, Mar 24, 2004 at 11:00:32 AM
Room Tags
Mon, Dec 4, 2006 at 12:42:20 PM
Area Planning
Wed, May 30, 2007 at 12:00:37 AM
text sizes
Fri, Jan 31, 2014 at 3:25:52 PM
Window sizes
Tue, Aug 29, 2006 at 2:07:39 AM
Page generation time: 0.1980
