Forums >> Revit Building >> Technical Support >> light height will not change??
Sat, Oct 4, 2014 at 10:15:36 PM | light height will not change??
willkerr
Hi,
I have been trying to put this chandelier into a project i am working on, no trouble getting it into the project and moving it around but I am having trouble adjusting the height at which it sits.
The only place i can seem to see any way to adjust the height offset is to edit the family, however this seems to make no difference when loaded into the project.
Edited on: Sat, Oct 4, 2014 at 10:47:26 PM
Sat, Oct 4, 2014 at 11:32:56 PM | light height will not change??
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Unlock 4’-0” dim and bring down the ceiling – use align tool. If you want to be able to adjust the chandelier height, you need to create a parameter to control its offset from the ceiling (or the floor).
Sun, Oct 5, 2014 at 12:39:46 AM | light height will not change??
willkerr
thanks pijpiwo. that works perfectly
light fixture height above floor
Mon, Nov 9, 2009 at 5:00:09 PM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
Change casework height based on countertops height
Tue, Jan 3, 2012 at 1:19:43 PM
Can I have objects in a parametric array change height?
Fri, Sep 3, 2010 at 3:06:21 AM
Can't control non-elevation height of light sconce (wall-based family)
Tue, Jan 4, 2022 at 3:42:00 PM
Page generation time: 3.1204
