62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Link/Joint/Connect Joist and Girders
Wed, Sep 24, 2014 at 9:22:08 AM | Link/Joint/Connect Joist and Girders
cboersen
I am uses Revit 2015
I have a large building that I got from another company as an as-built.  All the structure is included and in the correct location but the sloping is wrong.  When they inserted the structure they did not let the joists and girders link/joint/connect (not sure of Revit nomenclature) so now when I change the slope of the girder, the joists do not move/reslope with it.  My question is – is there a way to get the joists and the girder to link/joint/connect to each other even after they are placed or can that only be done at insertion?
Thu, Oct 16, 2014 at 11:22:52 AM | Link/Joint/Connect Joist and Girders
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yup it's too late. They should have enabled '3D Snapping' upon placement.
Joist Girders
Wed, Aug 22, 2007 at 6:02:57 PM
3 Panel Joist Girders
Thu, Feb 26, 2015 at 10:00:53 AM
Line weights of girders vs joists
Fri, Feb 24, 2006 at 12:56:21 PM
sloped joist framing/RAM
Tue, Nov 6, 2007 at 8:33:56 AM
Revit - Curtain Panels Mitre Joint Issue! Please Help!
Tue, May 28, 2013 at 8:58:14 PM
Page generation time: 0.9719
