583 Users Online (50 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Revit Save to central problems
Fri, Sep 12, 2014 at 6:55:36 PM | Revit Save to central problems
Uncluesteve
Last week a new server was installed and all production work was moved over to it.  Now we are experiencing some locking up whenever someone saves to central,  We have 3 or 4 people working on a file that is about 130Mb and everyone is pulling a new local file from the central file every morning.  Each time a user saves to central or modifies an existing object everyone that is working on the project locks up for a minute or so.  Now if a user add something or copies something there is no lock up.  It seams like every time a users modifies an existing object Revit is checking to make sure no one else is modifying that object.  Before the new server this process was almost instant.
All users are using Revit 2014sp3
Any ideas of what could be going on?
Here are the general specs and setup of the new server.
Host:
Dell T420 Server
6 core 2.1 Ghz Xeon
16 Gb Ram
Windows server 2012r2 W/ Hyper-v installed
Raid controller Dell PERC H710
Volume 1 Raid 1 Contains (C: Host os) (E: VM1 os & VM2 os)
Volume 2 Raid 10 Contains ( D: VHDX files for data shares)
VM1:
Windows server 2012 R2 (Domain Controller)
C: Virtual IDE (VHDX on E drive of host)
J: Virtual SCSI (VHDX on D drive on host) CryingLocation of Revit Projects)
R: Virtual SCSI (VHDX on D drive on host)
I: Virtual SCSI (VHDX on D drive on host)
VM2:
Windows server 2012 R2 (SQL based accounting software)
D: Virtual IDE (VHDX on E drive of host)
Mon, Sep 15, 2014 at 7:25:33 AM | Revit Save to central problems
I know nothing about the server spec so I can't comment on that.
I will suggest that there is absolutly no need to make a new local every day.  We've been using Revit a long time and have no problem with using our own saved locals.  Are you sure that someone is not really in a local?
Revit beginner & need help with worksets
Tue, Feb 12, 2008 at 9:55:04 AM
local file saving location [ 1 2 ]
Thu, Jul 10, 2008 at 8:03:09 AM
26
Multiple Users Syncing to Same Central File Issue
Fri, Apr 3, 2015 at 1:30:01 PM
Local and Central File locations
Tue, Sep 12, 2006 at 10:04:32 AM
Need to convert RVT file to RFA
Sat, May 22, 2021 at 6:14:06 PM
Page generation time: 0.9995
