48 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Revit 2014 Wall Sweep Clash With Window Sill
Good afternoon
I have a project with hardie siding so I created a new wall type and siding profile attached within the assembly. Added the profile to the wall no problem. Looks good. However when I add 30"x30" windows to the wall assembly in plan or elevation it only cuts the profile opening down to one level of siding on each window.
See attached.
If I remove the profile from the assembly no worries the window opening is fully cut out. Any ideas why this would happen? Doors work fine. my larger windows cut...baffled.
Cheers
You are discovering that this is a poor process. Not only do in-place sweeps not work at inserts but these walls won't work right at gables and they can kill a model.
Revit's materials work very well for small displacements in materials like you have with masonry and siding. Even metal siding with 1 1/2" displacement will render well with just materials. Does it look right in close up views of corners? No ... so you use detail work there.
If you must model these look at this post:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=17944&start=0
Edited on: Mon, Aug 11, 2014 at 3:16:47 PM
Revit 2013 - Window frame sweep with wall thickness |
Wed, Nov 28, 2012 at 4:03:26 AM
Window sill molding |
Fri, Jan 24, 2014 at 10:29:15 AM
widow head and sill sweeps |
Sun, Dec 11, 2005 at 5:46:13 PM
SLOPING CAST STONE WINDOW SILL APPLICATION |
Thu, Feb 28, 2013 at 8:38:42 AM
Window Sill Returns? |
Wed, Feb 18, 2009 at 10:58:57 AM
