Forums >> Revit Structure >> Technical Support >> Existing site elements
Mon, Aug 4, 2014 at 9:00:54 AM | Existing site elements
Davulsukur
I have a 3d Autocad survey and I am wondering if it is possible to use the 3d polys and levels to create existing site features?
I have tried to draw lines and effectively trace over the 3d cad data but 3d snaps don't seem to work and I always have to place lines on a reference level/plane which means if the existing site feature isn't flat, I cant accurately model it.
Any ideas on how I can go about this? I am trying model a railway platform, which is not flat from one end to the other.
Thanks
Mon, Aug 4, 2014 at 9:09:25 AM | Existing site elements
You would be far better off to model as Revit elements.  Modeling the platform as a floor would allow you to slope it as you need to to show existing conditions.
Tue, Aug 5, 2014 at 2:32:48 AM | Existing site elements
Davulsukur
Thanks WWHub. Seems like a good idea to keep everything as a Revit elements and using a floor should do the trick.
Next question: I have created a basic family, in this case a coper and i need to place these along the front of the platform. Do i have to place each one individually? Or is there a way to place multiple ones along an edge?
Tue, Aug 5, 2014 at 7:26:24 AM | Existing site elements
I don't know what a coper is.
If these elements are just placed at a fixed spacing, then array them.  If the move up/down - in/out with the edge then place them individually.
Block existing model. [ 1 2 ]
Tue, May 24, 2016 at 2:11:05 PM
16
Changing existing and new contour lines
Tue, Jul 17, 2012 at 9:08:56 AM
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
Site and phasing troubles
Mon, May 24, 2010 at 4:59:58 PM
Create new and existing topo lines
Wed, Feb 24, 2010 at 12:11:13 PM
Page generation time: 2.4294
