Forums >> Revit Building >> Technical Support >> If / Then Calculated Value
Sat, Jun 28, 2014 at 1:39:02 PM | If / Then Calculated Value
aaembree
Revit 2014
I am trying to build an Area schedule for a 3-story building, sorted by department.  Not all departments have square footage on all floors, so I am trying to do a calculated value such that if the LEVEL X (area) = 0SF, "---", LEVEL X.
Basically, if it's greater than 0, I want the actual value to show up, but if it is 0, I want it to read "---" in the schedule.
Mon, Jun 30, 2014 at 7:21:19 AM | If / Then Calculated Value
Sorry - you can't do that.  Numeric fields will only show numbers.
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated value
Fri, Aug 6, 2010 at 2:17:19 PM
Calculated Value
Mon, Dec 13, 2010 at 4:46:58 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Calculated totals of formula in schedule
Fri, Sep 11, 2020 at 7:14:07 AM
Page generation time: 0.0704
