Forums >> Revit Building >> Technical Support >> STL Exporter for Revit - Not Smooth
Fri, May 23, 2014 at 11:53:16 AM | STL Exporter for Revit - Not Smooth
Allan2010
Using Revit 2014 64-bit with STL Exporter for Revit installed.
When I export a revolved shape, then open in Makerware (v.2.4.1.62), the smooth surface comes our facetted.  I can't find any settings to correct this so does anyone have a work around?
The same shape, modelled in Rhino, exports without any problem.
How do you export to STL with materials
Tue, Oct 4, 2011 at 9:54:31 AM
.stl file creation?
Thu, May 17, 2007 at 12:50:53 PM
STL or VRML formats
Tue, Apr 25, 2006 at 5:31:56 PM
stl files
Fri, Mar 8, 2024 at 10:29:41 AM
hoe do you export an STL file for 3d printer
Mon, Jan 5, 2009 at 5:10:05 PM
Page generation time: 1.3033
