Forums >> Community >> Newbies >> Metric & Imperial template missing
Mon, May 19, 2014 at 9:33:23 PM | Metric & Imperial template missing
anugunjagre
Hi, I'm Anugunj.
I'm a starter with Revit Architecture. I'm not finding any metric & Imperial template in My revit architecture 2014.
When i went into the choose template option , it shoed me none.
Kindly help
Tue, May 20, 2014 at 7:15:42 AM | Metric & Imperial template missing
Reset your paths to the metric library templates and families.  The path is under the revit R dropdown / options / file locations. You can read about these settings in your HELP: http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-D9F26FE8-DB67-4F26-8860-C799ED01C255
Sat, May 24, 2014 at 1:06:37 AM | Metric & Imperial template missing
anugunjagre
Hi
I'm also not finding any library too. Different kinds of walls doors, windows etc. they are missing. from where should i copy or install them. Kind guide me please.
Thanks & Regards
Anugunj
Sat, May 24, 2014 at 5:58:34 AM | Metric & Imperial template missing
anugunjagre
Also
I've checked the  following folder which iare  empty :-
C:\ProgramData\Autodesk\RAC 2014\Libraries\US Metric\
C:\ProgramData\Autodesk\RAC 2014\Libraries\US Imperial\
Regards,
Anugunj
Tue, May 27, 2014 at 7:31:53 AM | Metric & Imperial template missing
Read the HELP:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-BE1F3684-1138-4698-8CEF-9FD09705D916
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
metric template
Mon, Apr 5, 2010 at 7:04:51 AM
Imperial metric question RAC2009
Fri, Jan 9, 2009 at 11:35:51 AM
Imperial Template
Sun, Jan 30, 2011 at 9:20:35 AM
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Page generation time: 0.3618
