18 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Re size drawings need help
Mon, May 19, 2014 at 11:27:49 AM | Re size drawings need help
joenharris
I drew a 13' tall wall in elevation.  But when I print it or put it on my title block,  it is tiny.  How do I make it proportionate to the title block I put it on..
Thank you
Mon, May 19, 2014 at 11:33:24 AM | Re size drawings need help
Change the scale of the view.
Mon, May 19, 2014 at 2:12:27 PM | Re size drawings need help
joenharris
Thank you.  That does make it look better on the sheet, but if I change it to 2, for example,  all my measurements double.  What am I doing wrong?
Mon, May 19, 2014 at 2:21:33 PM | Re size drawings need help
I really don't know what you are doing.   View scale is a drafting principle, it is not changing the size of the wall which it sounds like you are doing.
Maybe you need to know some fundamental drawing processes before you go any furthur.
sheet size
Fri, Sep 8, 2006 at 8:25:18 AM
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Sun, Feb 24, 2013 at 1:00:00 PM
File Size
Wed, Jan 23, 2008 at 8:48:19 AM
Updating town planning drawings from working drawings??
Thu, Apr 6, 2006 at 10:46:36 PM
How do I convert Revit drawings to AutoCAD drawings???
Fri, Sep 23, 2011 at 2:19:27 PM
Page generation time: 0.5086
