Forums >> Revit Building >> Technical Support >> fill patterns please help
Fri, May 16, 2014 at 2:25:47 PM | fill patterns please help
joenharris
New to revit.  I can sucessfully fill in a boundary with the plywood symbol, but when I try to fill in the next boundary with the concrete symbol, which shares a line with the plywood, it changes the plywood to the concrete symbol too.  I have even seperated the two drawings and it still changed my plywood to concrete.  How can I stop this and have 2 different fills on the same sheet?
Fri, May 16, 2014 at 4:04:28 PM | fill patterns please help
Johnzo142
Are you changing the type properties of your plywood fill pattern without first creating a duplicate and re-naming it to concrete? You have to have a fill pattern created for each type of pattern you want to display. If they share a a line, they still need to be two separate patterns, you cant have two patterns in the same boundary sketch.
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they?
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 1.3603
