Forums >> Revit Building >> Technical Support >> Property Line - Color
Mon, May 12, 2014 at 10:16:50 AM | Property Line - Color
JBA7
I am having trouble with the color of my property lines.  It is only showing up gray or half-tone.
I have looked in the Visibility/Graphic Overrides and there is no override or half-tone checked.
My View Template is set to 'black' and there is no View-Specific override.
I am able to change lineweight but not the color.  Any suggestions?
Thank you in advanced!
Mon, May 12, 2014 at 10:33:05 AM | Property Line - Color
What are the settings for property lines under manage tab/object styles?
Mon, May 12, 2014 at 11:45:21 AM | Property Line - Color
JBA7
Projection: 3, Cut: 1, Line Color: Black, Line Pattern: Double Dash 3/8"
The Site Category is also set to Black for color.
Mon, May 12, 2014 at 12:08:13 PM | Property Line - Color
It is a setting somewhere ... wish we could help more.
You drew the lines?  You do know that individual elements can be over-ridden ...not just by filters?
Mon, May 12, 2014 at 12:26:38 PM | Property Line - Color
JBA7
Yes, I have changed the properties for the 'Property Lines' in every place I could think of.
Thanks for trying, I will update if I happen to figure it out.
Mon, May 12, 2014 at 2:15:02 PM | Property Line - Color
archigrafix
5 Stars: 4 Votes
I have no problems overriding the colour of the property line under: Site / Property Line. Is there where you are changing it? Have you tried as WWHub says, select it and override graphics in view (right click), by element to the colour you need. Is the property line in your model? Is it linked model? Is there a filter that overrides it? It would be nice if revit would shown in the properties all applied overrides to troubleshoot this kink of issues.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, May 13, 2014 at 7:24:53 PM | Property Line - Color
JBA7
Hi Marc,
Yes, I have adjusted the settings in each place.  The conclusion I am leaning towards is a corrupt view template.
The property lines were drawn in the model, no links, no filters.
Still troubleshooting...
Wed, May 14, 2014 at 6:03:39 AM | Property Line - Color
archigrafix
5 Stars: 4 Votes
That might be view template bug. Sometimes we have to disable a view template and re-enable it to get the settings to apply properly.
Marc Faber
Tue, May 15, 2018 at 3:04:55 PM | Property Line - Color
hkman25
Have you try Discipline? Sometime it happened to me. I switched Electrical to Coordination and it worked. The property line was half tone and now it changed to black solid.
Property line
Tue, Oct 13, 2009 at 5:31:57 PM
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
How to draw this property line?
Sat, Jan 23, 2016 at 4:48:18 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:57 PM
Property Boundary lines
Tue, May 30, 2006 at 10:45:31 PM
Page generation time: 0.4600
