48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Material Library
Fri, May 9, 2014 at 1:36:30 PM | Material Library
malenenielsen
Hi All!
I have a problem with that when I go into my design and said edit type to change in my design I can when I click on it where I can go in and vægle a material will not open.
Is there one of you who know what this problem is and how it can be solved.
It must be said that I have not jaft problems with it so far and it is in both my model and when I open a new project that it is wrong.
Fri, May 9, 2014 at 1:54:54 PM | Material Library
Sorry - I don't understand your question.   "...........and said edit type to change in my design I can when I click on it where I can go in and vægle a material will not open. ." << ?
Fri, May 9, 2014 at 2:05:36 PM | Material Library
malenenielsen
Sorrry instead of vælge there should stand select
Question about shared custom material library
Wed, May 18, 2016 at 6:44:31 AM
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:17 AM
Material library
Fri, Mar 3, 2006 at 9:11:37 AM
Material Photo's Library
Tue, Dec 8, 2009 at 3:19:26 PM
Help me! Lack of BMCD2AR3 material library in revit building 8.
Sat, Oct 8, 2005 at 9:54:16 PM
Page generation time: 0.2521
