Forums >> Revit Building >> Technical Support >> Revit Shortcut to enter dimension
Tue, Apr 1, 2014 at 11:17:10 AM | Revit Shortcut to enter dimension
bhamWade
Working in Revit 2014
For instance, when specifying an offset, is there a way to specify the distance without having to click in the little "Offest:____" bar & having to drag over to select the existing text, then quickly type dimension?
In Autocad, you just have to type the command & type the distance. Much more efficient...
Trying to streamline my detailing over here.
-WADE
Tue, Apr 1, 2014 at 12:51:24 PM | Revit Shortcut to enter dimension
Revit does better then CAD.  Don't do offest.  Just start to place and when you see the temporary dimension, you don't even have to pick it.  Just type your number.
Tue, Apr 1, 2014 at 1:56:21 PM | Revit Shortcut to enter dimension
bhamWade
Thanks for the reply, WWHub.
I hear ya. However, in a complex drawing with many lines / objects / detail components, this rarely performs as desired. I'm looking for a shortcut to get the cursor in that silly little box. I feel like it's one of the few things that I have to go to the tool bar for. I had a feeling that this shortcut does not exist, probably needs to be a wishlist item.
Maybe my workflow is just wonky from streamlining my CAD drafting...
Wed, Apr 2, 2014 at 9:35:23 AM | Revit Shortcut to enter dimension
BTW - You do know how to see what shortcuts are available ...?
Revit R pulldown/options/user interface/keyboard shortcuts/customize
Wed, Apr 2, 2014 at 10:31:50 AM | Revit Shortcut to enter dimension
bhamWade
Ha! yes. KS! I'm pretty far gone from the OOTB shortcuts at this point ;-)
I also use a programmed RAZER Mamba.
Wed, Apr 2, 2014 at 10:34:33 AM | Revit Shortcut to enter dimension
bhamWade
& a 3DConnexion
I don't see how all you Ribbon / Dropdown people get anything done...
Wed, Apr 2, 2014 at 10:36:36 AM | Revit Shortcut to enter dimension
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Mind if I ask what 3Dconnection you use?
Wed, Apr 2, 2014 at 10:45:32 AM | Revit Shortcut to enter dimension
bhamWade
Just a SpaceNavigator. I'm strictly architecture, if I was doing Intense 3D modeling one of their other $$$$ products might be convenient, but right now my left hand is on a small keyboard, typing commands. I switch over to the SpaceNavigator when I'm in perspective (checking work, showing things to clients, getting a sense of spaces). Then I have a handful of my most frequently used commands programmed into the RAZER Mamba...
Wed, Apr 2, 2014 at 10:46:33 AM | Revit Shortcut to enter dimension
bhamWade
The SpaceNavigator is extremely nice to have & I HIGHLY recommend it.
KEYS
Tue, Jul 31, 2007 at 8:46:34 AM
Valueless Dimensioning
Wed, Apr 27, 2005 at 6:52:43 PM
How to set parameter for levels.
Tue, Jun 14, 2016 at 11:53:22 AM
DIMENSION TEXT
Tue, Jun 5, 2012 at 10:17:41 AM
Another Way to Shortcut
Wed, Sep 10, 2008 at 10:44:57 AM
Page generation time: 1.3232
