Forums >> Revit Building >> Technical Support >> Family Different From What I Created When Loaded Into Project
Fri, Mar 28, 2014 at 2:55:48 PM | Family Different From What I Created When Loaded Into Project
Chumlee67
(Currently usung Revit Architecture 2014)
I edited a preloaded revit windoew family to a window design that I needed and it worked perfectly.  I saved as tthe preloaded family as a separate file, then proceeded to do the same to a second custome file.  the problem I am having is when I go through the process of editing the extrusions; I load the family into the project and it maintains the previous versions desing.  Even when parameters have been altered.  Any help you be great.  Thank you.
--Kevin
Sun, Jun 15, 2014 at 5:11:34 AM | Family Different From What I Created When Loaded Into Project
raja15
Hi Kevin,
Could you upload a screenshot of the window in family edit mode and when it is is loaded into the project?
Thanks
Nested family missing when host family is loaded into project
Wed, May 13, 2009 at 7:36:11 PM
loaded revit family
Mon, Feb 4, 2013 at 8:11:07 AM
Having Problem rotating family after it is loaded in the project...(see pic)
Thu, May 22, 2008 at 2:49:26 AM
Voids don't work when family is loaded into a project
Mon, Mar 1, 2010 at 8:13:26 AM
Can't rotate object loaded to project
Fri, May 17, 2013 at 11:21:10 AM
Page generation time: 1.3169
