18 Users Online (16 Members):
Forums >> Community >> Newbies >> Revit Building 8
0 Posts No Rating |
I just joined. I have Revit Building 8 in my highshool classroom and need help periodically. Most recently I tried getting a Family of Doors from Autodesk but when I tried to Load from Library, select Family and select the object I saved (Double Raised Panel with Sidelights) it tells me "the file was saved in a later version of Autodesk Revit and cannoyt be retrieved in this version". I saved it from the Revit Building 8 Archived libraries from the Autodesk website accessed when you select Web Library. Can anyone help?
I thank Autodesk is getting rid of all th old libraries.
As a teacher and class, you can have the latest Revit. Why are you not doing this? If it is a computer problem, at least come up to 2012 Revit. That will still work on your system.
Moving a Building |
Wed, Apr 30, 2008 at 5:49:59 AM
Problem: How to cut building into landscape |
Fri, Apr 1, 2011 at 3:02:59 PM
WHY THE A.REVIT BUILDING GOES SOOO SLOW? |
Fri, May 4, 2007 at 2:43:19 AM
Underground Building Issues |
Fri, Oct 17, 2014 at 1:55:33 PM
Building Pad for cantilever building |
Thu, Dec 20, 2012 at 6:33:52 PM
