Forums >> Revit Building >> Technical Support >> Glass Spiral Staircase Creation- Help :)
Fri, Mar 14, 2014 at 12:29:50 PM | Glass Spiral Staircase Creation- Help :)
QuinnC
I am a student in need of help. I'm trying to make a modern house, but I need a spiral staircase with an all glass handrailing. If anyone could take me step-by-step, that would be great!
Thanks-
Q
P.S. I tried to follow other guides and got confused, I want something like the picture inlcuded.
Fri, Mar 14, 2014 at 12:31:16 PM | Glass Spiral Staircase Creation- Help :)
QuinnC
Oh and I use Revit 2013
Fri, Mar 28, 2014 at 7:56:44 AM | Glass Spiral Staircase Creation- Help :)
limanlemon
you could remove all handrailing and have 900mm high balusters with no spacing between, this would achieve the effect
Fri, Mar 28, 2014 at 8:02:12 AM | Glass Spiral Staircase Creation- Help :)
archigrafix
5 Stars: 4 Votes
Do you have the chance of using revit 2014 instead? We have modeled a few spiral stairs by component (not by sketch) using revit 2014 and as long as the stair is not more than 360 degrees it should be fine. Have in mind that by default revit assumes that the center line of the stair is your step depth.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Spiral Staircase
Sun, Sep 24, 2006 at 9:05:44 PM
Spiral staircase
Wed, Mar 7, 2007 at 8:57:42 AM
Staircase and glass railings
Fri, Sep 6, 2013 at 7:51:05 AM
Spiral Extrusions
Mon, Feb 1, 2010 at 5:40:22 PM
Spiral Staircase does not show on second floor
Tue, Apr 14, 2009 at 6:31:20 PM
Page generation time: 0.3020
