9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Automatic Ceiling error - less than 150mm
Hi.
I was wondering if someone could tell me if there is a know bug in Revit when creating a ceiling via "automatic ceiling" and there is a wall in the room that has a corner (or right angle kink) of less than 150mm (6"). If I increase the wall length to 154mm, then it works.
Regards, Chris
Are you saying the ceiling ignores the 6" wall? I am not having a problem with it going around a 6" wall but I may not be understanding what you mean. Do you have all of the updates installed for 2014? I'm also assuming your using 2014.
Ceiling serious error |
Thu, Oct 16, 2014 at 10:59:43 AM
Revit Ceiling Causing "Serious Error Has Occurred" Message |
Thu, Aug 29, 2013 at 3:01:57 PM
Automatic Family |
Tue, Sep 15, 2009 at 4:29:57 AM
Sloping Ceiling |
Mon, May 25, 2009 at 2:35:31 AM
Walls will not connect to ceiling or roof |
Mon, Mar 2, 2015 at 8:25:47 AM
