Forums >> Revit Building >> Technical Support >> revit crash
Wed, Feb 5, 2014 at 3:11:53 AM | revit crash
janekR
Hey,
 I got a problem with revit 2014. It keeps crushing durig simplest actions(sth like every 10s), but only on one particular project. I was running it for two weeks and everything worked fine...it happend suddenly and i can't even return to previous backup vesions as the are damaged as well...
The error report contains following files:
-journal.0055.0001.dmp
-dmpuserinfo.xml
-dumpdata.zip
-journal.0055.txt
does anyone got a clue how can i get rid of this problem?
would be really grateful for any help...
cheers!
Wed, Feb 5, 2014 at 7:55:01 AM | revit crash
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have all of the updates installed for 2014? Is this a workshared project?  Did you try Auditing the file?
Wed, Feb 5, 2014 at 8:19:27 AM | revit crash
Send the problem and data to autodesk.
Thu, Feb 6, 2014 at 8:24:15 AM | revit crash
janekR
got all the updates and it's not a shared project but...Auditing helped!! at least so far no error appeared. I'm new in revit and wasn't familiar with this option...
Thanks a lot!!!
Crash!!!!
Thu, May 5, 2011 at 4:09:10 PM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 7:38:36 AM
11
Revit Link causes crash
Wed, Dec 29, 2010 at 10:33:38 AM
Crash for single user on workshare projects
Thu, Jun 26, 2014 at 2:56:50 PM
Parametric Cabinets causing crash in RAC 2010
Tue, Aug 11, 2009 at 1:21:18 PM
Page generation time: 5.6085
