Forums >> Revit Building >> Technical Support >> Hiding Paint in a 3D view
Tue, Jan 28, 2014 at 10:20:40 AM | Hiding Paint in a 3D view
MPeters17
I am using paints to represent and calculate formwork needed for slabs, walls, columns, block-outs, and so on; and I have multiple 3D views with filters for varying purposes, but my goal is to have the paint represented on only one of the 3D views to minimize confusion due to colors used multiple times, or as a result of having too many colors/patterns on one view. What is the best way to go about doing this?
Thank you for any help you can provide.
Tue, Jan 28, 2014 at 10:22:50 AM | Hiding Paint in a 3D view
Sorry but you should not be using paint for this.  Paint is a material and is 3D... all views.  Find another method.
Tue, Jan 28, 2014 at 10:27:00 AM | Hiding Paint in a 3D view
MPeters17
Thanks WWHub
Paint phasing work around ?
Mon, Jun 1, 2009 at 2:41:15 PM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Paint Help
Wed, May 22, 2013 at 5:33:21 PM
How do you tell what finish has been applied with Paint?
Sat, Jan 26, 2013 at 5:14:41 AM
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
Page generation time: 1.5073
