45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Horizontal section
Sat, Feb 18, 2006 at 1:59:01 PM | Horizontal section
cima
Is there a simple way to make an horizontal cut and hide everything up this plane?? A part of the previous question: is there a way to hide part of a stair ??? as always thanks
Sat, Feb 18, 2006 at 6:01:38 PM | RE: Horizontal section
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
A horizontal section would be a plan?? So yes... If this isn't acceptable you can create a detail section at any angle. A stair will always show the extended element above the cut dashed. This is a system property that i don't think can be changed. If its that critical i'd place a filled region over it to block the unwanted section.
Sun, Feb 19, 2006 at 3:53:02 AM | RE: Horizontal section
Xane
You can also put 'plan region' and define view range for that plan region specialy to see or hide something
Mon, Feb 20, 2006 at 7:03:11 AM | RE: Horizontal section
cima
well, of course the question wasn't very clear. what I want to do is to cut in a camera view, with the object to make 3d view of 1st floor, without having to modify all that is over it. (hide elements is not enough, as i want to cut walls at 1,5m, for example). It is an horizontal section, but not to be seen on plans, but in 3d views. it is a bit clearer?? I hope so...
Mon, Feb 20, 2006 at 11:17:53 AM | RE: Horizontal section
eepa
5 Stars: 2 Votes
You have to use the Section Box. In the 3d view, left click, Properties-> and check Section Box. Hope it helps.
Tue, Feb 21, 2006 at 3:36:10 AM | RE: Horizontal section
cima
that one was the order I was lookin for,eepa! thanks to all anyway.
HORIZONTAL SECTION
Wed, Apr 7, 2010 at 5:49:36 AM
Horizontal section references on elevations
Tue, Jul 31, 2012 at 3:25:32 PM
14
Curtail wall on Sloping mass - mullions to be horizontal
Wed, Apr 24, 2013 at 10:01:29 AM
callout annotation in section w/ coresponding section anno in plan
Mon, Sep 24, 2007 at 1:33:19 PM
custom section head rotation (2019)
Fri, Dec 14, 2018 at 9:28:45 AM
Page generation time: 0.4934
