13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> Civil 3D 'shared reference point tool' and 'Integration with Civil 3D' revit ext
0 Posts No Rating |
Hello All,I've set my Revit project up using the 'shared refrence point tool' in civil 3D, which work fine, (Although i did have to set my project level to zero to get the levels to work?).I'm now trying to bring in a Civil 3D surface using the 'Integration with AutoCAD Civil 3D', which works fine bringing in the surface at a true north orientation. The problem is, when the surface is brought in, the previously set revit coordinates are then broken! The Civil 3D surface is correct to true north, but the underlying revit project is displayed in project coordinates. When i try to change the revit project to true north nothing happens? I've tried various configuration, such as linking in the revit file, but always there is this disparity between Civil 3D at true north and Revit at project project?It's a shame, both tools work well independantly, but there seems to be an issue when working together, please can someone help?ThanksAlex
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
revit structure 2012 add-in "integration with civil 3d": routing error? |
Wed, Jan 25, 2012 at 2:56:13 AM
CIVIL DRAWING AND SHARED COORDINATES |
Tue, Mar 25, 2008 at 2:42:58 PM
'Out of Memory' pop up |
Tue, Sep 6, 2005 at 3:16:07 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:32 AM
