Forums >> Revit Structure >> Technical Support >> Can you help me with this 2d component
Tue, Nov 19, 2013 at 8:15:44 AM | Can you help me with this 2d component
sblake
This is very simple, I know. I made a 2d component to show where our lintels will be on the plan. I want to be able to move the lintel mark (L-1) around. Currently, it is in a fixed location. Can you help? I have attached the family.
Revit Structure 2012
Tue, Nov 19, 2013 at 8:48:14 AM | Can you help me with this 2d component
You really can't do what you want to do.  The Lintel mark needs to be seperate.
Why are you not using the elements built into Revit?  You can use a model element and tag it.
Tue, Nov 19, 2013 at 9:45:24 AM | Can you help me with this 2d component
sblake
We don't model cmu block lintels. We mark it on the plan and include a schedule on our drawings.
Tue, Nov 19, 2013 at 9:52:54 AM | Can you help me with this 2d component
I understand but you are using Revit.  Why not use the power of this program?
You can "draw" a model lintel just as fast as you can draw your line.  And the model element will schedule and tag.
Tue, Nov 19, 2013 at 10:06:14 AM | Can you help me with this 2d component
sblake
Does Revit have cmu block lintels?
I was under the impression that you also have to be careful what you do model because of file size, etc.
Tue, Nov 19, 2013 at 10:17:35 AM | Can you help me with this 2d component
I would assume you use the precast concrete beam family.
Tue, Nov 19, 2013 at 10:28:35 AM | Can you help me with this 2d component
sblake
I guess that would be an option, but it would not be correct. We use reinforced cmu masonry block.
Ok, thanks
Tue, Nov 19, 2013 at 10:38:51 AM | Can you help me with this 2d component
Your original question did not say this was reinforced masonry so I assumed steel and your next post still didn't say that so I assumed precast.
You mean lintel block with rebar?
Then I would probably use a family modified from the precast family that would tag accordingly.  But lets see if anybody just shows the rebar?
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
LOADING COMPONENT [ 1 2 ]
Sat, Apr 11, 2009 at 5:30:13 AM
24
Model in place component
Wed, Oct 11, 2017 at 11:46:05 AM
Converting a component into a wall?
Tue, Apr 6, 2010 at 9:30:33 AM
rendering /component issue
Sun, Jun 12, 2011 at 8:28:07 AM
Page generation time: 0.0907
