Forums >> Workflow & Implementation >> API & Third Party Apps >> Central Model Lock Advice
Wed, Oct 23, 2013 at 10:32:22 AM | Central Model Lock Advice
JD24
HI Everyone
Just want to get peoples opinion on having the Central Model inaccessible to local users. I would like to lock the central model so that nobody can actually get in there and work in there and save. But I would also like to have the local user be able to sync in that file.
What I did is that I gave read permissions to the central file to everyone. But they cannot sync to it.  So that option didn't work.
Does anyone have any other options so that people don't go into the central file and muck it all up. This is just precautionary as most of you probably already have had people corrupt the central file and worked in the central file. Nothing good really comes out of it.
Any advice would be great.
Thanks
Wed, Oct 23, 2013 at 10:40:21 AM | Central Model Lock Advice
I don't see a way to make it idiot proof.  You have to always stress good practice.
It used to be that you had to tell Revit to create a local when you open the central.  But that is the default now so we don't see any real problems.
Converting Central Model to Basic Model
Wed, Jul 2, 2014 at 11:48:21 AM
Central Model Update issue MEP2013
Mon, Nov 12, 2012 at 9:09:32 AM
Detaching from Central Model...I CANT!
Fri, Aug 27, 2010 at 10:26:55 AM
Lock a Revit model down / Read Only for issue to Builder
Wed, Jan 18, 2017 at 9:38:47 AM
Working over WAN central model
Sun, Aug 26, 2012 at 9:59:26 PM
Page generation time: 1.6334
