Forums >> Revit Building >> Technical Support >> R2014 - help with parametric modeling, fixing grid lattice
Wed, Oct 23, 2013 at 10:31:39 AM | R2014 - help with parametric modeling, fixing grid lattice
ItWasLuck3
Hello all,
Long story short, I'm a student and I've created a quarter funnel as a conceptual mass. I applied intersects based upon a series of reference planes I created. I then created a geometry based upon the 1/2 step family. However, there are a number of errors in the lattice after it's applied.
See here:
http://i.imgur.com/9r6kvJD.png
http://i.imgur.com/fsvisuQ.png
http://i.imgur.com/2K4wgM7.png
http://i.imgur.com/vOFC3Gl.png
http://i.imgur.com/zgoOewh.png
At the bottom of this, I have attached the file I was working on. In order to stay under the 2MB limit, I had to disable my pattern, but if you open it, click on the two seperate grids, then apply the pattern "Geometry Test 4" and the model will regerate and look like the images above.
Any help would be awesome.
Cheers.
Lattice Under Decks
Thu, Apr 10, 2008 at 9:47:32 AM
Parametric window
Thu, Dec 13, 2018 at 12:27:15 PM
Multi axis curtain grid
Wed, Dec 23, 2009 at 9:27:00 AM
Lattice Girder Column
Fri, May 25, 2012 at 6:36:25 AM
locking an array overconstraints?
Fri, Sep 10, 2010 at 10:29:51 AM
Page generation time: 0.3358
