76 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Length Families
Wed, Oct 23, 2013 at 3:11:53 AM | Length Families
Orla90
Hi, I'm Currently making a window sill family in revit, I've already set a length formula to restrict the min and max size, =if(Length<3600,if(Length>600,Length,600),3600), That worked fine, but now i need to restrict the size of the sill from 600mm-3600mm in intervals of 150mm, so for example 600-750-900-1050-1200....3600,
Does anyone know if there is a way to do this, Thank you
Wed, Oct 23, 2013 at 10:21:36 AM | Length Families
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
It sounds like you are trying to make it so you can use the shape handles to stretch and snap / the size to dedicated 150mm dimensions. If thats the case I would just create new 'Types' with the predetermined sizes. That's what types are for.
Adjustable length in component families
Mon, Jul 26, 2010 at 1:45:33 PM
Wall Length for Wall hosted family Length
Sun, Mar 2, 2008 at 2:54:20 PM
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:04 PM
Stretch Length of family
Tue, Nov 14, 2017 at 3:58:50 PM
length in beam tag
Sat, May 26, 2012 at 12:25:40 AM
Page generation time: 2.1192
