6 Users Online (4 Members):
Forums >> Revit Building >> Technical Support >> Door angle
2 Posts No Rating |
How do you change the door angle?
if you don't have the parameter in your family, you will need to put one in.
in short:
in your door family, draw a reference line on an angle, dimension it (using angled dimension) add parameter, call it door angle and lock your door panel to it (the lines that represent your door swing)...
eldados as usual has the answer. there is an excellent tutorial on this very topic in help - check it out.
3 Posts No Rating |
How do you lock your door panel to it?
your question indicates you may not have studied the family tutorials. this is so important, and i know the good operators did this. i have looked really hard at them and practiced, practiced, for 4 years now! but . . . door panel symbolic lines should be drawn on reference line as per the tutorial, and 'locked' to it. you will need to play around with this somewhat to get the right lock. also, it is a good idea to dimension the door panel thickness, so the parallel line follows the locked one. i occasionally find it best to also dimension the width, especially with complex multi-folding doors. hope that helps
Door angle |
Thu, Aug 25, 2005 at 4:41:59 PM
Fully Parametric door with 45 angle swing |
Wed, Mar 26, 2025 at 11:13:10 PM
Adjustable angle door family |
Thu, May 14, 2009 at 2:30:09 PM
creat double door w/ adjustable swing |
Mon, Apr 27, 2015 at 1:30:05 PM
Door angle in plan parameter |
Thu, Jul 2, 2015 at 1:22:34 PM
