59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Custom Surface Pattern not working
Fri, Aug 23, 2013 at 2:02:58 PM | Custom Surface Pattern not working
ncl21
Ok first time poster.
i'm trying to create a surface pattern for horizontal siding that has two different width profiles. Everytime time i try and load my .PAT file it says  No 'Model' type patterns found. I have created it as a Model Pattern so why is doing this...
Here is what I have written in my .pat file
%UNITS=INCH
*Horizontal Lap Siding- 10 3/4" x 4"
;%TYPE=MODEL
0,      0,      0,      0,      4
0,      0,      0,      0,      10.75
Fri, Aug 23, 2013 at 2:12:28 PM | Custom Surface Pattern not working
I don't have the units on any of my files and I can't remember where that is allowed or the proper syntax.  Erase it and see what happens.
Fri, Aug 23, 2013 at 5:18:36 PM | Custom Surface Pattern not working
hugh
3.5 Stars: 4 Votes
Erase the UNITS line to default to INCHES or add a leading semicolon to comply with the required syntax, viz:
;%UNITS=INCH
Your pattern superimposes two sets of siding widths giving a quasi-random effect. This will alternate the two widths:
;%UNITS=INCH
;%TYPE=MODEL
0,      0,      0,      0,      14.75
0,      0,      4,      0,      14.75
Hugh Adamson
www.hatchkit.com.au
Custom Surface pattern.
Wed, Jun 2, 2021 at 2:14:47 AM
mssing surface pattern
Tue, Jul 3, 2012 at 10:49:25 AM
Custom divide surface pattern?
Wed, Jan 22, 2014 at 4:14:59 PM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:52 AM
Page generation time: 1.3513
