Forums >> Revit Building >> Technical Support >> probebly no solution for this one :(
Wed, Aug 14, 2013 at 10:23:28 AM | probebly no solution for this one :(
Dafpfy
3.5 Stars: 11 Votes
Check images,
one is from revit and the other one is a render in the cloud.
in the cloud render the white building should be located on the far right where all its interior components are.
when i render on my local pc the problem doesnt happen.
using rac 2014
note that this project has been started in rac 2011 and has been transfered true 2012-2013-2014
what is probebly causing this problem.
any suggestions are welcome but i suspect that i will have to render this one localy.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, Aug 14, 2013 at 10:32:47 AM | probebly no solution for this one :(
Send this problem to autodesk
Deleting Doors
Mon, Dec 8, 2008 at 9:12:16 AM
INTERIOR render
Tue, Aug 23, 2011 at 3:10:20 AM
Please Help!
Thu, Nov 20, 2008 at 9:52:59 AM
Visibility Overwrite Solution?
Wed, Sep 15, 2010 at 12:19:43 PM
Searching for the instances of a family within a project
Thu, Mar 14, 2013 at 8:23:17 AM
Page generation time: 0.2277
