Forums >> Revit Systems >> Technical Support >> Has anyone had issues using Charlotte pipe families for piping in 2014?
Tue, Aug 13, 2013 at 3:50:48 PM | Has anyone had issues using Charlotte pipe families for piping in 2014?
jcrocco
3 Stars: 1 Votes
I was trying to make a new template using better plumbing fittings from Charlotte pipe.  Fitting like 90 ells, tees, etc. rather than the default Revit ones.
I downloaded their files.
I found out that now in 14, we need to merge the .csv files with the families. so I did that,
Even so, I cant get the fittings to work.  They do have connectors.
If I draw a default pipe and make a 90 and change the ell to one of the Charlotte Fittings, it errors out.
If I add it to the properties of the pipe type, so it draws it in as a default, it errors out.
Just wondering if someone knows of a work around.
Fri, Nov 1, 2013 at 9:14:27 AM | Has anyone had issues using Charlotte pipe families for piping in 2014?
narlee
where did you even find the csv files?Smile
Piping System Families
Mon, Dec 3, 2012 at 3:46:31 PM
pipe visibility
Mon, Apr 13, 2009 at 12:45:12 PM
Piping families...
Mon, Oct 22, 2018 at 9:20:59 AM
pipe insulation and VG
Fri, Sep 6, 2013 at 2:08:39 PM
Piping Detail level...
Wed, Nov 19, 2008 at 4:54:30 PM
Page generation time: 0.6169
