4 Users Online (2 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> Room Elevations Generator
Hi there, I am currently working on a live project in Revit. i have been asked to room elevations for all 140 rooms! Does anyone know if there is a Code or Plugin out there that will do this on the click of a button, I am using REVIT Architecture 2012.
Kind Regards,
David
Twelve highlanders and a bagpipe make a rebellion.
If you set up a view template for your room elevations it really wont be that bad. Just place the elevation>adjust the width and apply the view range. I don't think theres anything that will just do it for you.
Thanks Teafoe. I was pretty sure I heard that someone created an API coding that allows you to do this : (
I have a project that I have to create room elevations for 140 rooms which has to be done by a the end of next week. Fun
Thanks again,
David
Revit Text Generator |
Fri, Feb 4, 2011 at 1:33:36 PM
Hatch Pattern generator |
Thu, Oct 6, 2005 at 1:49:14 AM
Room Elevations - Side walls not Printing??? |
Fri, Feb 13, 2009 at 7:09:57 AM
API For all room elevations in one building model |
Wed, Dec 17, 2014 at 1:19:51 AM
Autodesk Labs - Structure Generator |
Wed, Dec 14, 2011 at 5:07:26 AM
