2 Users Online (0 Members):
Forums >> Workflow & Implementation >> Hardware >> How can I install Revit to have my families folder located in Drive D
87 Posts No Rating |
I want to install Revit but have Empirical Libraries folder in another drive? Will I have problems running the program if I do this?
Why I am considering this is because I want to more easy access my Empirical Libraries folder. Also I have two drives. Drive C is the SSD and I dont want to overload it with too many files so that my programs run more smoothly. My D drive is quite big
Is this weird?
Copy or move the folder and change or add path at 'Load Family' browser.
want more?
You can get more tips at Enjoy Revit |
You can have your library anywhere on your network but you will need to set your path. Click on the revit R and pick options at the bottom then reset the paths under file locations.
Revit Architecture 2013 Missing Families on Install |
Sat, Oct 13, 2012 at 9:54:27 AM
64 bit install and (x86) folder |
Thu, Jan 1, 2009 at 2:27:59 PM
Pattern file location on drive |
Wed, Mar 18, 2015 at 12:26:06 PM
Network License Manager |
Tue, Oct 9, 2007 at 8:27:06 PM
Entourage folder is missing |
Fri, May 13, 2011 at 5:05:47 PM
