155 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Scheduling a non-modeled item
Fri, Jul 5, 2013 at 12:25:54 AM | Scheduling a non-modeled item
sharannya23
Hi,
  I have made a nested family and loaded it into a project environment. My requirement is that i need to add an item in schedule which is not created as a model either in the family or project.This item should be counted once per each instance of the family loaded into the project. Is there any way by which i can achieve that?
Thanks in advance
Sharannya
Fri, Jul 5, 2013 at 9:02:30 AM | Scheduling a non-modeled item
You are talking in circles.
"...  I have made a nested family and loaded it into a project environment..."   A nested family is not nested if loaded into the project, it is just a family.  A nested family is loaded into another family - thus nested.
"....i need to add an item in schedule which is not created as a model either in the family or project....This item should be counted once per each instance of the family loaded into the project..."  Never created but counted per instance.   That's an oxymoron.
Please clarify your question.
ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
Thu, Nov 2, 2017 at 8:03:01 AM
Scheduling Wall Layers
Wed, Nov 4, 2015 at 11:24:08 AM
Revit LT Select an Item
Fri, Dec 13, 2013 at 9:17:51 PM
Rendering Modeled Siding [ 1 2 ]
Fri, Oct 19, 2012 at 10:00:44 AM
25
Scheduling Issues - rounding up
Mon, Feb 16, 2009 at 12:56:01 PM
Page generation time: 2.4227
