45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Plot Prefix and Prompt
105 Posts No Rating |
Revit 2013:
When you plot individual seperate files to PDF, is there a way to get rid of the prefix before the sheet number other than doing it manually at each file/sheet name prompt?
Related to that ... is there a way to stop Revit from prompting for each file/sheet name and just going thru the full selected set without stopping - similar to what it does if you select combine multiple?
I hate sitting here removing the prefix and hitting return (or even just hitting return) when I have better things to do.
"... is there a way to stop Revit from prompting for each file/sheet name...?" < This is not a Revit issue, but your PDF printer driver. You can buy PDF printer programs that will do what you want.
OK, make sense, I will look into that.
What about the Prefix before the sheet number?
Plot Preview in PDF |
Wed, Feb 22, 2012 at 11:28:24 AM
Plot log |
Thu, Feb 5, 2015 at 8:06:04 AM
Prefix in dimension style |
Thu, Dec 16, 2010 at 9:15:11 AM
raster image will not plot |
Thu, Sep 24, 2009 at 8:43:42 AM
Electrical circuit prefix separator |
Sun, Mar 8, 2015 at 11:29:34 AM
