71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Paragraph Bullets Disappear
Wed, Jun 19, 2013 at 8:09:15 AM | Paragraph Bullets Disappear
cboersen
I am using Revit 2013.  When I am editing a paragraph I can add bullets using "Paragraph Format" and they show up as long as I am editing the paragraph.  As soon as I exit the text, the bullets disappear.  The indent still shows but the bullet icons are gone.  Any ideas about what might be wrong?
Wed, Jun 19, 2013 at 12:29:44 PM | Paragraph Bullets Disappear
It works fine on my 13 .... so the next question is - Do you have all the updates?
BTW - AutoDESK just released update 3 for 2013.
Wed, Jun 19, 2013 at 1:40:01 PM | Paragraph Bullets Disappear
cboersen
I believe I have all the updates.  I am using a custom font, but when I switch to a standard font the issue remained.  HMMMM.
Wed, Jun 19, 2013 at 1:48:07 PM | Paragraph Bullets Disappear
You should have answered that you have Update Release 2 - not I believe.  Just beside the ? - the pulldown "About AutoDESK Revit 2013"
We use Ariel and it works.
Wed, Jun 19, 2013 at 2:31:04 PM | Paragraph Bullets Disappear
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Sometimes it depends on whether or not the font type supports bulleting. (Most do)  Is it a true type font?  Serif, sans-serif?  I might be able to offer some suggestions.  We use Ariel.
Its comic sans your using isn't it?  Winking
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Wed, Jun 19, 2013 at 2:49:24 PM | Paragraph Bullets Disappear
cboersen
We are still on release 1.
We use a custom font for our company called DVCC and it does not looking anything like any of the fonts in Revit (I'm not sure why the big cheeze here thought that was necessary) and bulleting does not work for that.  I had switched to RomanS, and as fate would have it, bulleting does not work for that either.  When I switched to Ariel it works fine.  Thanks for the hints.  Is there a way to "fix" a font so bulleting will work?
Wed, Jun 19, 2013 at 3:04:48 PM | Paragraph Bullets Disappear
Under your system start, select Run and then type charmap.  This is a graphic display of the truetype fonts available on your system.  Find the one closest to your bullet and copy - paste that into your line of text instead of using the automatic bullets.
BTW - YOU SHOULD AT LEAST BE ON RELEASE 2!  That fixed a lot of problems
Edited on: Wed, Jun 19, 2013 at 3:57:48 PM
Fri, Jun 21, 2013 at 8:12:50 AM | Paragraph Bullets Disappear
cboersen
That is a neat trick.  Thanks.
Controlling Bullets/Line Spacing
Tue, Apr 7, 2015 at 8:41:49 PM
elevation bullets handle
Wed, Jun 8, 2016 at 3:08:08 PM
Bullets & Numbering in Text Boxes
Thu, Oct 16, 2014 at 11:20:06 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Text line height spacing - can it be changed like the width?
Mon, Dec 19, 2011 at 7:41:58 PM
Page generation time: 7.3235
